Thread: 3" Pucks Dissolving Slowly
    14,500 gallon pool with ILC that uses 3" pucks. I'm adding about 1lb. of shock every 3-4 days. My CYA is at 35, Ph at 7.6, and TA at 110. My pool is in direct sunlight about 80% of the day and we've had quite a bit of rain for the past 2 weeks. The past week I have only went through one puck running the pump 24 hours. I pretty sure I should be burning through a puck every 2-3 days. Before that, I was burning through 2 pucks per week. Any suggestions?
    May 2013
    North East Ohio
    959
    Re: 3" Pucks Dissolving Slowly
    I would re-read the POOL SCHOOL - running long term with pucks will sky rocket your CYA.
    As for dissolving so slowly...I can't really comment.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    LOL, Yeah, lose the pucks and learn to use the BBB method touted here!
    You'll save a ton of money and most likely have a much nicer water quality.
    Do you have a good pool test? Have you read the Pool School articles here to learn all about pool water maintenance?
    I find it very satisfying to be in charge of my own pool quality, as apparently I'm pickier and want better water than what most pool stores promote.
