Results 1 to 9 of 9
Thread: raising pH using fountain
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    What can I expect when trying to raise pH using this fountain?
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: raising pH using fountain
    That your ph will go up ...sorry I couldn't resist. I would think that fountain will do a great job. Are you in the process of lowering TA?
    esim13's Avatar
    Oct 2009
    320
    hahaha!... you got me! I guess I was asking for that one!
    I'm not in the process of lowering TA. I guess I should be raising it. It was only 20 today!
    pH was yellow! Never had it go that low before. I'm not quite sure what happened to lower either one.
    Here are all of my numbers from today..
    FC 6
    CC 0
    ph 7
    TA 20
    CH 40
    CYA 80
    I know CYA is a bit high. I just came back from a two week vacation and used pucks to help FC level. I'm okay with it that high right now. It usually drops during the season bc of rain, evaporation, overflow and water replacement. Any other suggestions?
    GEAUX TIGERS!
    Pics taken 2012
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It is important you get your TA up using baking soda to at least 60 ppm. Then recheck your ph and adjust from there.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I just saw you said you were surprised how low TA was. What was it before? I would check it again before adjusting.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by esim13
    FC 6
    CC 0
    ph 7
    TA 20
    CH 40
    CYA 80
    The pucks not only raised CYA, they lowered pH and TA.
    esim13's Avatar
    Oct 2009
    320
    Thanks Linen and Richard! I didn't realize pucks lowered pH and TA... no more vacations for now so I'm on it.. Baking Soda here I come.
    One more thing.. am I good to leave the fountain going for a day or so?
    GEAUX TIGERS!
    Pics taken 2012
    Richard320's Avatar
    Jan 2010
    19,009
    Why? Your TA is so low I wouldn't expect it to raise the pH much.
    esim13's Avatar
    Oct 2009
    320
    That's fine... I would just like to enjoy it another day or two before I put the eye back in the return...
    THANKS!!
    GEAUX TIGERS!
    Pics taken 2012
