Stain help
May 25, 2010
52
Fairfax Station, VA
I have a plaster pool and SWG.
There is a tan stain on the plaster which is worst around the main drain in the deep end. I dropped some ascorbic acid tablets on the stain and it turned black. I brought the water to Leslies and it tested negative for iron and copper. I don't want to purchase any stain removers until I know what I am dealing with. Any ideas?
FC 4
TC 4
Salt 3100
CH 200
CYA 60
TA 120
pH 7.8
Not sure what it is, maybe tannin stains? Did you have a lot of leaves lay in the bottom of the pool for a long time? Try dropping a trichlor tablet on the stain and see if it makes a difference.
