Thread: Haywood DE Filter replacing Pressure Gauge
    Do I have to open up the filter to replace the pressure gauge? Or does it just screw into the top of the filter? I know I have to turn the power off and bleed out the air before I remove the old pressure gauge. I found a video on youtube that makes it look simple enough.. wasn't the same exact filter though. Thanks for any help..
    38,397
    Re: Haywood DE Filter replacing Pressure Gauge
    Welcome to TFP!!!
    It just unscrews ... no need to open the filter (just turn the pump off and crack the bleed valve).
    Liquid filled gauges will last longer.
    Thanks!!
