Thread: Pool & Underground Utilities
    We have been looking into a pool for a while and thought we had everything planned out and enough room and such, but I completely overlooked the gas line to our house. No matter where I would put a pool in my back yard, I will end up overlapping the the gas line by about 18". By our city code, we can not do this.
    My question is, is this just due to the fact they do not want you to have to potential issue with the gas company ever having to repair the line, forcing you to remove the pool, or is there another issue, like the fact that the gas line may only be burried to 18" or so and the weight of the pool being able to crush or bend the line as it compacts this soil? I have looked everywhere and cannot find any one mentioning a dangerous aspect, just the utility easement thing.
    Basically, I am just looking to see if the idea of me having a pool in this yard should be scrapped or not.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool & Underground Utilities
    Call the gas company and inquire about having the line relocated.
    Jun 2013
    Newcastle, Oklahoma
    508
    i wouldnt worry about it. my gas, phone, water, and electrical lines all run right in the middle, underneath our 3 car wide driveway on our new house. that pool isnt going to hurt your lines anymore than all that concrete and vehicles will hurt mine. the only lines you can really hurt with weight are septic lateral lines, and even then it takes a lot of weight.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    SW Indiana
    9,199
    Quote Originally Posted by gtnos
    You can't get a permit to install the pool if it doesn't meet the city code.
    Feb 2012
    Cypress, TX
    131
    I would look into moving the line. Even a 10,000 gal pool weighs around 80,000 lbs in a pretty small area. I would thing that it could cause some compression of the ground. There are reasons for the city codes.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by JohnT
    true. my bad as i dont have to have a permit for AG pool where im at....
