Thread: Newbie vacuum question
    May 2013
    Virginia
    75
    What happens when you vacuum? Does the water still go through the filter? My daughter vacuumed the pool last night before a pool party and did not turn the vacuum off. After the party (15-20 kids in our small pool) the water was cloudy, could not see the bottom. I bleached and let the pump run another 3 hours or so before shutting it off for the night. This morning the pool was still just as cloudy so I went and looked at the pump and she had not turned off the vacuum as she thought she had. So I'm just wondering, where does the water go when vacuuming? Since I turned the vacuum off (about an hour ago) the pool is becoming clearer.
    10,000 gallon inground, gunite, 500lb sand filter. Brand new to this pool thing.
    38,251
    Re: Newbie vacuum question
    Is your vacuum a suction side cleaner? If so and you just have a 3-way valve on the suction line to select between the skimmer and the cleaner, then the water just goes through the filter like normal.
    May 2013
    Virginia
    75
    Hmm, it is a suction side cleaner (I prime and hook a hose up to it), with a 3 way valve. I thought it went through the filter, but the returns had a lot less water jetting out of them while the vauum was on.
    38,251
    Do you switch to full suction through the vac or just partial?
    If full, there is a lot more resistance through the vac, so the flow rate will be less. Odds are the vac does not need full flow (usually they have a gauge so you know if you have the right amount of suction) and you could keep the skimmer partially open which would increase the flow rate through the system.
