Results 1 to 9 of 9
Thread: heater - 100 ft from pump/filter
    Good morning,
    Just put in an above ground pool last summer and now are installing a gas heater for our 16*26 above ground pool BUT the filter/pump is about 100ft away from the main gas line. While we could have the gas line brought out- it is VERY expensive to do this so it was suggested that we install the gas heater close to the gas line, and simply run some Tigerflex hose from the heater back to the pump/ filter. Anybody done this? is there too much stress on the pump?
    Thanks for any advice you can provide!
    Re: heater - 100 ft from pump/filter
    Welcome to TFP!
    Running water from the pump out 100' and back 100' will require a different kind of pump than most above ground pools use. Long plumbing runs like that require a high head pump, while most above ground pumps are low head pumps. You might be lucky and have a medium head pump, which will kind of work, though the efficiency will go way down. But trying that will a low head pump will cause problems.
    How can I tell if it is a medium head pump?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    post the brand and model of the pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    A heater bypass would help so you are only pushing as much as the heater needs to work properly. This would help minimize the head loss in that line.
    Plus putting in flex is expensive. So is there any reason you can't use larger ridged PVC lines?
    Mark
    30,421
    Off the basic subject but a run off 100' (underground?) may noticeably reduce your heat gain.
    It is a Hayward pump
    1HP
    Model number: has been scratched off but it is SP....
    11.8 Amp
    There is another number EC1309 next to the CSA sticker....
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Would it be cheaper to install a propane tank, convert the heater to propane heater, and install it near the pool as opposed to 200 feet of pipe and all the associated heat loss and pump issues?
    Just an idea.
    -- Guy --
    Apr 2013
    Westside LA, CA
    49
    I would try to get better quotes on running that gas line (or DIY) - In the long run that might be less expensive than 200ft of pipe and associated heat losses.
    32x15 IG Borate+Salt, Pentair VS+SVRS, howard swim pure 40 SWG, Pentair 4000 48sqft DE, Mastertemp 300, Electric Pool Cover, Polaris P93, 4 Kids for Aeration, ;)
