Results 1 to 10 of 10
Thread: Adding salt
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Adding salt
    So I am new to all this, so if I am off base please let me know. I would like to add salt to my pool for the added "feel". I do not have a SWG, so how is the best way to add it? Just dump SLOWLY and brush? Does the salt effect the pump and filter? Pool Calc says 350lbs to get 2000ppm, which I have read on here is a good number without a SWG. I have a t-100 and use BBB. Is there any chemical number I need to be at, like with borates, before adding? any advice good or bad would be helpful.
    test last night...
    FC 6.6
    CC 0
    ph 7.8
    TA 110
    cya 60
    CH 190
    brought the PH down to 7.2 and TA to 100
    IG 16x32 Grecian - Vinyl - Approx 18k gal - 1 HP Hayward Super Pump - Pentair Triton II TR-60 Sand Filter - Hayward ColorLogic Light - Hayward H250FD Heater
    38,415
    Re: Adding salt
    Just dump it in. It does not impact any other level.
    We just had a birthday party and I was dumping the 40 pound bags onto the kids swimming at the time ... I think some of the parents briefly freaked out
    The kids loved playing with it ... often referred to a "Diamond Day" on the forum.
    BTW, you can use solar salt for much cheaper than the "pool" salt.
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Re: Adding salt
    Awesome! thanks much! going to add it this weekend. This might be a dumb question.... but is it safe to assume that my salt level is now Zero? I will buy a test kit, but I would like to add salt ASAP.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Adding salt
    Quote Originally Posted by chclark
    You will have some level of salt in the pool. All sources of chlorine leave salt behind.
    You're done SLAMing when:
    Jun 2011
    Long Beach, CA
    2,790
    Re: Adding salt
    This situation is one time that I recommend going to a pool store and let them test the salt level. Don't bother buying a salt test for yourself as you would hardly if ever need it.
    38,415
    Re: Adding salt
    I was at 1200 ppm salt before adding any bags. So you certainly want to test before adding any.
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Re: Adding salt
    great thanks!!!
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Re: Adding salt
    update.
    Got the salt test strips along with speedstir (awesome). Im going to add salt tonight. Lowes has pellets and crystals which route should I go? They are only about a $1 differnece in price.....
    38,415
    Re: Adding salt
    I used the solar salt from Lowe's. Pellets are fine as long as they have no additives, they will be slower to dissolve.
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Re: Adding salt
    So I tested the salt using test strips from tftestkit.net before adding salt reading was about 300ppm. Pool calc said to add 320lbs to get 2000ppm. So I did that saturday, and tested last night. Test strips are saying 1000ppm...there is a very slight salt taste. Is this normal at 2000ppm? seems that the strips were off. im hoping that I didnt add too much...... not sure that i trust the strips. hopefully the inital reading of 300 wasnt way off base.
