Results 1 to 7 of 7
Thread: New owner of an old pool....
    Hello Everyone,
    This coming month I am closing on our new home, which contains a circa 68 vinyl lined inground pool. The surrounding area needs work, but the pool itself appeared to be in decent shape. Plus the filter is nearing its end of life. I figured it would be best if I have the pool serviced the first year since I will be renovating the interior for most of the summer. However, I would like to learn as much as possible this year before jumping into DIY maintenance next year. Starting off with the most critical items; the filter & diving board.
    About the filter; I know its getting close to its end of life and would like to prepare for its eventual replacement. In reading some information online; I was under the impression it might be worth replacing the filter system with the following:
    -Increase the skimmer line to a 2" with a larger skimmer.
    -Install a separate 2" pressure type cleaner line for an automatic cleaner
    -Provide a minimum 60 sf DE filter
    -Provide a hayward 1 (maybe 1.5) HP filter.
    -Provide a timer on the filter system
    Any thoughts on this proposal? And is it possible to DIY the whole thing? Seems very scary..
    As for the diving board; attached is a photo of the base. The previous sellers "misplaced" the board. Just wondering if I can find a replacement board or do I have to install a new one?
    Any help you guys could provide would be helpful. Thank you in advance.
    ~kalats
    (New owner of an old pool)
    33K gallons, IG-Vinyl, Sand Filter -PF Triton, Hayward 1HP, circa 1968
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New owner of an old pool....
    Welcome to TFP!
    Replacing plumbing is very involved because you have to either dig under the concrete decking or remove part of it and then dig. 2" is probably overkill for a cleaner.
    Be careful of oversizing the pump. More than likely you can get by with a 1HP pump or even smaller.
    I'd run with what you have for a while before considering major changes.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    The timer is a nice addition and is fairly easy to do, either diy if you've done electrical before or for an electrician.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Thanks guys for the sage advice. Any input on the diving board?
    ~kalats
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Check with your home insurance company before making any plans to repair / replace your diving board, some of them will not cover pools with diving boards, it seems to be about a 50/50 split on the issue.
    SW Indiana
    9,199
    I don't recognize the stand. If you could find a brand name anywhere on it that would be a huge help.
    Alright John. I will take a look at it next time I am there
    ~kalats
