Thread: Adding CYA with 3" pucks ?
    May 2013
    Long Island NY
    419
    So my CYA is at 20 and I need to raise it a bit. If I put some 3 " pucks in my clorinator and run my pump 8 hrs a day will this just take to long to bump it up another 10 or 20?
    Can adding the 3" pucks be calculated in any way to help zero in on the dosage?
    Or should I just go out and buy some stabilizer.
    Thanks
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Adding CYA with 3" pucks ?
    Each puck will add about 2ppm of CYA to your pool.
    May 2013
    Long Island NY
    419
    Ok that works, thanks John
