Thread: Adding CYA to pool.
    Adding CYA to pool.
    Hello ~
    I am new to pools. We set the pool up less than a week ago. How should we add the CYA? At the moment we have it in a floater with a sock around the floater. Is this a good way to add it or should we purchase a Intex Krystal Clear Wall-Mounted Pool Surface Skimmer and place the CYA granulas in a nylon sock in that?
    How often do most people run their saltwater system and sand pump? We have had to unplug it for a good part of yesterday and last night due to severe storms.
    Also, is severe weather or heavy rain a problem for the system?
    Thank you for any help!
    Rachel
    AG Vinyl Intex Easy Set 15' x 48" 3,736 Gallon with Intex 1600 GPH Saltwater System & Sand Filter Pump Set
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Adding CYA to pool.
    Welcome!
    Bobbing around off a float works. Or hang it from a string in front of the return jet. You just don't want it sitting in the skimmer or the filter or on the floor of the pool.
    Have you read Pool School yet? The link's on the upper right of every page.
    Thank you!! Yes, I am reading through it. Very very helpful as I feel overwhelmed!
    Thank you again!
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Being new to this site can be overwhelming but the more time you spend on it, the more familiar it will become.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Thank you!!
