Results 1 to 7 of 7
Thread: pool cleaner for sandy environment
    May 2013
    Ocean County NJ
    183
    Hi, I live by the beach and we track a lot of sand around which is unavailable. Will an automatic floor cleaning system work or will the sand clog the piping? Thx for suggestions!
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    30,424
    Re: pool cleaner for sandy environment
    What does that mean?
    May 2013
    Ocean County NJ
    183
    Will sand get stuck similar to a sink tra, in pvc piping.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Sand is unavoidable? I don't think it'll get caught in PVC pipe...traps are meant to hold stuff whereas the pipes are not designed to do so. Flow rates are high enough to move it right along.
    I know my cleaner (in-floor type) really stinks at taking care of sand...but I don't know what kind would be good! Stick around and someone will help.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Aquabot 4WD gets sand. How about a garden hose by the pool?
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    30,424
    I doubt the in-floor system will deal with sand very well. However, a robot or auto-vac will handle it very nicely.
    May 2013
    Ocean County NJ
    183
    Thanks for advice guess ill go for suction cleaner.
