Thread: Intex pool forum...Should they have there own?
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    What are your thoughts on a dedicated Intex pool forum??
    It seems 50% of the topics in the above ground pool forum are about Intex pools. Do you think it would be helpful to Intex owners t go directly to that forum for help and advise rather than search thru above ground??
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Intex pool forum...Should they have there own?
    I see this as a double edge sword, sure there are many Intex specific questions, since Intex does try to be somewhat proprietary, but at the same time we have so many Intex owners that they easily get answered in the other sections. The real problem I see here though is that the newbies would have to distinguish between a generic pool issue and an Intex specific one (What kind of Chlorine should I use in my Intex pool?...)
    Ike
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    A pool is a pool is a pool. Even if it is only spa sized. It still needs care and chemicals to keep it clean and safe. The only thing different about Intex from a regular pool be it AG or IG is the pump and filter arrangement. You have to hand it to Intex type manufacturers, they have made pool ownership attainable for us not so "well heeled" people.
    I'll open a new thread with an idea or two I have, in the pump section.
    Apr 2013
    Central Massachusetts
    174
    The only reason to add more sub-forums, in my opinion, is because you are getting too many active topics each day in any single sub-forum. Looking at the most active forum here, today's active topics don't even fill up one page (almost does), so there's no need to split things up further. Co-mingling is a good thing.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
