Thread: Pool overflowing
    Apr 2010
    Central Illinois
    205
    Pool overflowing
    Hi everyone, we had massive rain last night.....1. Do I have to drain pool or can I just let it keep coming out over skimmer?
    2. I shocked pool all day yesterday and did overnight test this morning and the results were FC13.5 FC12.5 CC0
    OK to swim today?
    Thanks!!!
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Re: Pool overflowing
    You should keep the water level about 1/2 up the skimmer to it works properly. You can swim up to shock level.
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    If the water is above the top of the skimmer opening, you should drain the pool down to that level. Depending on which pool/skimmer design you have, it might be designed to overflow before that happens, or it might not.
    Jul 2007
    Hillsborough, NC
    520
    The easiest way to drain your pool is to set the filter to Waste and let the pump do the work. You might also take the opportunity to backflush the filter.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Apr 2010
    Central Illinois
    205
    Thanks will drain a little today!! Just to clarify...I did the Overnight Fc Test last night results were 13.5 this morning they were 12.5 Is that considered passing the test or does it have to be .5 ppm or less?
    Thanks again, the kids are dying to swim!!!!
    TF-100
