Thread: What can go wrong with 300W 120V 12V pool light power suppl
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello gurus and others.
    My 300 watt power supply is having issues. When I turn it on it always doesn't come on. If I bang on the front of it it comes on. Fuse is tight in the holder. connector wires are tight. anything else you can think of.
    Turn it on, whack it, lights till I shut it off. That pretty much sums it up.
    Advice please.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: What can go wrong with 300W 120V 12V pool light power s
    Are you hitting the bulb or the power supply? Either way it is obviously a connection problem. If it is the power supply and you checked all the connections in the power supply, it could be broken wire in the transformer winding which would be very difficult to fix unless it is on one of the terminals. Also check the solder joints. Sometimes those will loosen.
    Mark
    Apr 2011
    Murrieta, CA
    2,360
    Yeap it's the wall mounted power supply (not the bulb). I'm thinking it might be the windings, cause the wire connections are good 12V/120V sides (wire coming in, and going out). Looks like I might have to pull it and bench trouble shoot it.
    Apr 2011
    Murrieta, CA
    2,360
    Re: What can go wrong with 300W 120V 12V pool light power suppl
    Ended with swapping it out with a PX300. The connector for the fuse corroded out. Sealed and couldn't replace.
