Results 1 to 10 of 10
Thread: swim up bars!!
    May 2013
    Ocean County NJ
    183
    swim up bars!!
    Looking for swim up bar ideas for a small pool around 13k gallons. please share your pictures
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    Re: swim up bars!!
    Built in bar stools will mean an in floor cleaning system. Just a heads up. If not your cleaner will get caught up every time. Good luck!
    13K IG Pool with Raised Spa
    Jandy E Pump- 2HP Variable Speed
    Jandy CV460 Cartridge Filter
    Jandy LXI 40,000 Heater
    Polaris 9300 Robot
    May 2013
    Ocean County NJ
    183
    Re: swim up bars!!
    Never thought of that, thanks for the heads up!
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Re: swim up bars!!
    I was going to put one in but decided instead that I would look into the removable bar stools instead. They aren't as aesthetically pleasing, but they're very practical and can be removed which negates an in-floor cleaning system and also means they don't take up space in the pool when not needed. A good compromise perhaps.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    Re: swim up bars!!
    I'm not aware of the removable models. Please share some pics.
    Polaris 9300 Robot
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Re: swim up bars!!
    This is one option.
    http://www.thepoolstool.com/photos.php
    I'm not mad about the looks but I think functionally it works.
    This is another, again not mad about the looks:
    http://poolstools.net/store/solid-colors-c-106_109.html
    This is another concept I saw but haven't seen it to buy...
    http://inhabitat.com/floating-pool-bar/aquapub/
    Jan 2011
    Richmond, Texas
    595
    Re: swim up bars!!
    Quote Originally Posted by CAVJOCK22
    My friend has a swim up bar in his pool and the builder installed his cleaner opposite from the bar stools. So basically they just made sure the cleaner would not be able to get caught by making sure the cleaner hose was not long enough. It gets everywhere else in the pool.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    May 2013
    Ocean County NJ
    183
    Re: swim up bars!!
    Any pictures to share anyone?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: swim up bars!!
    I wouldn't have a swim-up bar. I'd want to make people get out of the pool periodically...and while they're out to get a fresh drink, they can use the bathroom.
    As an aside, I remember this pool in Serbia from last year refilling-the-pool-need-some-help-with-pool-calculator-t51909.html
    Re: swim up bars!!
    We are doing a small swim-up bar in our pool. (We do have an in-floor cleaning system)
    My Pool Build: http://www.troublefreepool.com/updat...ix-t59520.html
    35x18 IG PebbleSheen; Pentair CCP520 Clean&Clear+ Filter; Pentair Variable Speed Inteliflow Pump; Intelichlor SWG; A/A In-Floor Cleaning System; Spa; (3) Pentair MagicFall Water Sheers; Baja Shelf w/Bubbler. Build Date: Est Completion 7/3/13.
