Thread: Should I add DE to sand filter
    May 2013
    Hartsville South Carolina
    46
    This has probably been asked many times but a lot of the info I searched is a couple years old. So, should I add DE to my sand filter. If so where do you get it(other than a local pool store) and is there a sticky or something about DE on here. I read how to add it but was wondering more about why to add it. Thanks so much, Ryan
    23k gal, IG, vinyl, Pentair sand filter, 1 hp single speed pump, pool pilot digital swg, Hayward sharkvac. Built May 2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Should I add DE to sand filter
    How is pool-school/add_de_to_a_sand_filter
    Why is if the pool is cloudy after the shock process or whatever and is taking too long to clear.
    [center:1v6dj5g4][/center:1v6dj5g4]
    38,370
    You can find it at Walmart (Filter Aide is one name), or hardware stores if you do not want to go to the pool store.
    The article is right in the How To section as far as how: pool-school/add_de_to_a_sand_filter
    As to why ... well if you have to ask you do not need too It can just be helpful to filter out smaller particles or speed up clearing a cloudy pool ... no reason beyond that.
    May 2013
    46
    Thanks guys, I guess I don't need to add it then. I didn't know if I was missing something. Like "you didn't add DE to sand. Oh my". Thanks again for quick responses.
