Thread: WATER LEVEL
    WATER LEVEL
    I have been having to lower the water level 2 or three times in the past week or so due to storms. and the kids using the slide that is hooked to the water hose no hard task but I was thinking if I drilled a small hole in the rear of the skimmer where I would like the water level to stay would this work . would it hurt anything. when the water gets above the hole it slowly comes out of hole until at the right level again do you guys see anything wrong with this
    15x30x54 AG,2HP2SP PUMP 400LB SAND FILTER
    Re: WATER LEVEL
    Sure, that would work. You will get some leakage even below your target water level, as waves will occasionally raise the water level up to the hole for a moment. But that shouldn't be too much of an issue, especially with the slide adding water regularly.
    38,521
    Re: WATER LEVEL
    Although you may not want the water to just accumulate right next to the pool ... maybe see if you can attach a hose to divert the water away?
    Re: WATER LEVEL
    good idea thx guys
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: WATER LEVEL
    How handy are you?
    If it was me...I'd drill a hole in the skimmer at the overflow level and install a bulkhead fitting, then a hose nipple, and then run a hose off to wherever. Go to a mom-n-pop hardware store and tell them what you are doing and what you want and I bet they fix you up. Remind them it's not a pressure system.
    Google it and you'll see all kinds of pictures of a bulkhead fitting.
