my green water is gone 2 gallons of bleach did it , chlorine still testing very high with my cheap test kit. water is still a little cloudy but it gets more clear as time goes on.edglsi76 said:I ordered the TF-100 it will be here in a few daysIsaac-1 said:it depends on the type of algae, some turn white, some brown or gray, some even kind of stay green even when dead. The problem is now you are half blind doing the shock process as you have no test tell if you are maintaining shock level. You may add enough bleach to get to shock level then be back below shock level a couple of hours latter giving the algae a chance to regrow, this is why the suggest FAS-DPD test is so important to have.
