Thread: What psi should my pump/filter run
    Newbie with used pool here, and I have questions about my pump and filter setup. I have a jacuzzi 1 hp pump with a 17" 150 lb sand filter. What should my psi run, and at what psi should I backwash. The previous owner couldn't find the paperwork for it. Thank you all in advance.
    [i][color=#BF0040]27' x 52"....1.5 HP hayward pump 200lb sand filter.....finally building our deck :)
    The clean filter pressure varies from pool to pool. You should backwash when the pressure goes up by 6 to 8 psi from where it is when clean.
    Thank you JasonLion. Clean it is running 15 psi, so I will backwash before 25 psi. Thanks again.
    Apr 2008
    Central Texas
    That sounds reasonable. My DE filter runs at 13 PSI just after a backwash, then I backwash again once the pressure gets into the 20-22 PSI range.
    I have noticed that since I added the borax and am using bleach that my filter doesn't need backwashed nearly as often.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
