Results 1 to 13 of 13
Thread: Sun screen
    May 2013
    Hartsville South Carolina
    46
    Sun screen
    This may be a dumb question but I need to ask. I have been reading elsewhere that pool owners don't like when people slather up with lotion then get in the pool. Do pool owners not like lotion? I have been genetically blessed with very little hair on my head. If I didn't wear sun screen my head would be bright red and not very pleasant feeling. Do you guys wear sunscreen? Does it mess the water balance or something? Thanks or your thoughts. Ryan
    23k gal, IG, vinyl, Pentair sand filter, 1 hp single speed pump, pool pilot digital swg, Hayward sharkvac. Built May 2013
    May 2013
    Miami, FL
    23
    Re: Sun screen
    I feel like it soaks up chlorine and clouds up the water...it also soaks the cartridge filter in oil and makes it harder to clean
    pool owner since 2012
    13-15k gallons, kidney shaped,in-ground plaster
    1970s construction, currently undergoing complete renovation
    3 jets, 1 skimmer, 1 dedicated vacuum line, kreepy krauly great white, main drain
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Sun screen
    About the only pool store additive I use is a bottle of enzymes to break it down if I've had a few in all slathered up!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Sun screen
    If you allow it to soak in, there wouldn't be much problem. But far too many people slather it on and jump in immediately, and you can actually see the oil slick they leave behind!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Sun screen
    I only mind the one's that slather it on and the jump right it. It just washes right off. Don't you people understand!!!!
    The ones that let it soak in for several mins. are doing it right......
    I did notice upon opening this year i had a scum line i didn't at closing. I also took my DE filter completely apart to clean after 1 year of use and it was nasty. I attribute both issues to sunscreen use.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Sun screen
    The spray on sun screen seems to make much less of a mess and is much easier to apply in my opinion. It seems like thats all our family and friends use anymore. Head sunburns are the worst!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    May 2013
    46
    Re: Sun screen
    We also use the spray. I try to make my kids wait fifteen minutes after applying. I just spray them down then take my time getting my suit on. Thanks for everyone's input.
    Re: Sun screen
    Quote Originally Posted by Richard320
    This! I have seen it. A friend of ours found it necessary to cover himself with about 5x the required amount for a early afternoon swim around 5:30 when the pool becomes shaded by trees anyway.
    Reminds me of the cloud that liquid chlorine creates, only the lotion clouds aren't a good thing. And it doesn't seem to disappear as quickly either.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Sun screen
    I'd say that 80% of what I clean out of our cartridge filters each year is sun screen. My wife uses the pool for water therapy every day so with that much sun exposure she needs to use sun screen so a lot does get into the pool water, though as was noted by others letting it soak in first helps. It produces a film on the water, but that doesn't last too long.
    May 2013
    North East Ohio
    959
    Re: Sun screen
    Just a side note, been reading those spray on sunscreens might have quite a few more chemicals that we've bargained for...so buyer beware !
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Re: Sun screen
    Quote Originally Posted by woodyp
    I'm having this issue right now after a couple of large pool parties....what is the name of the product you use?
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    Apr 2010
    East Texas
    9,621
    Re: Sun screen
    ****!.I'm out or I'd tell you! Nothing special for sure. Maybe a quart sized bottle that says to only add about 8 ounces or so. Wasn't expensive at all. Dangit.......back to the pool store before the 4th holiday!
    Sep 2012
    Mid-Michigan
    127
    Re: Sun screen
