Thread: Is the Liquidator Right for my Pool?
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    I have read many of the threads on the HASA Liquidator and it sounds pretty appealing as it related to managing my FC.
    I have read some issues around head pressure that could be related to larger pools. Also, understand that the larger the pool the more frequently it would need to be re-filled (Liquidator).
    I have a 23,000 gallon in ground plaster pool, 2 skimmers, main drain (4 heads), and 2HP PlusHP Jandy pump. I typically add in around 6 gallons of bleach per week. Based on this I would need to refill likely once per week. The benefit would be versus adding every day and a more stable FC level.
    I am looking for feedback as to whether the Liquidator would be a worthwhile addition (and it would work - pressure) for me in regards to FC maintenance.
    Thanks in advance for you comments and input!
    Rawlins
    23,000 IG plaster pool, Jandy HP Plus 2HP (130 GPM), Jandy CV460 Cartridge filter, Polaris 280, Jandy LXi 400,000 BTU Heater, Jandy Watercolors LED lighting, 7' Raised SPA
    22,553
    Re: Is the Liquidator Right for my Pool?
    You could make it work, but you're getting very close to the size pool where I wouldn't recommend it. You've obviously thought about the implications so you already know that you'll have to fill it pretty regularly. If you're willing to put up with that, then go for it.
    Have you considered an injection pump and tank?
    Mar 2012
    Central FL
    80
    I agree with Bama. If I had to refill my Liquidator with chlorine every week, I would be miserable. I think a pump/tank with more capacity would be ideal, though a bit more expensive.
    Jose
    17x34' 13400gal freeform gunite IG pool, DB Tahoe Blue, cartridge filter, Rainbow 320, ClearO3 ozonator, 1.5HP 2sp Whisperflow, Intellibrite 5G Color LED, pavers, screened enclosure, Liquidator, 6x Fafco SunSavers, SolarTouch
