Thread: acid damage to rocks, or scale?
    jeffreymlewis's Avatar
    Jul 2012
    Walnut Creek, CA, USA
    7
    Hello,
    About a week ago I noticed what looks like calcium scale on one rock near my pool. Thing is, the white marks are way above the water line. This rock is near (within 2' of) the area where I drop chemicals (Cl, HCl, etc...).
    Is it possible these white marks are damage caused by muriatic acid? If so, how can I prevent this from spreading? I've already brushed the rock and sprayed with copious amounts of water. (After brushing, the white marks disappear for a while, then reappear after the water dries.)
    Here are some pictures.
    Jeffrey
    15k gal, IG painted plaster (black), 3.0 HP Intelliflo VS, Pentair CCP240, MiniMax 400, build date unknown (estimate 1995), attached spa w/ water fall
    30,432
    Re: acid damage to rocks, or scale?
    That looks like efflorescence....... minerals migrating to the surface from behind and evaporating/precipitating once they reach the surface.
    Muriatic acid will clean it off. I don't think there is a cure other than time
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Rocks are natural and absorb the minerals from the pool water. What you are seeing is calcium. Also into the mortar joints.
    Try acid washing with a strong solution 1/3 acid water and a stiff brush. It should form or bubble.
    Then balance your pool after the acid gets into the pool water.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Jul 2012
    7
    Ok cool, I'll give it a try. Thanks for your suggestions!
