Results 1 to 11 of 11
Thread: Cartridge Filter or Sand Filter
    Jun 2013
    Auburn, AL
    16
    I currently run a cartridge filter and have been told that I should switch to a sand filter. Comments or recommendations?
    Jonathan Smart
    17,000 Gallon, In Ground, Gunite, Sand Filter, VSP, Installed 4/2016,
    22,548
    Re: Cartridge Filter or Sand Filter
    Why do they think you need to switch? What problems are you having?
    Welcome to TFP!
    What kind of filter you use is almost entirely a personal preference issue. There are some differences between the various filter types but they are fairly minor. For example a cartridge filter makes the most efficient use of water, since rinsing the cartridge off takes much less water than backwashing a sand or DE filter. DE filters filter down to a smaller particle size than other filters, sand is the "worst" and cartridge filters are in-between. However, most people can't detect any difference caused by that.
    The main differences are in the approach to cleaning the filter. Cartridges get removed and rinsed off, sand gets backwashed, and DE gets backwashed usually and occasionally needs to be opened up and throughly cleaned.
    The size of the filter make a dramatically larger difference than what kind of filter you have. Larger filters can go longer between cleanings and are slightly more efficient.
    Jun 2013
    Auburn, AL
    16
    The problems that I am having with the cartridge filter is that I am having to buy a new one every year at a cost of $150 -$200. My pool installer said that I should not have to replace them but ever 5 years or so. Also I have to clean it on a weekly basis after they told me I should not have to do it but once a month. Also I have to run my pump on level 3 or 4 out of 4 just to have the correct flow.
    Jonathan Smart
    22,548
    Sounds like more of a size issue than a design issue. If it's too small then switching to a sand filter may not be a bad idea. However if it's really a water quality issue that's causing you to have to clean it and replace it regularly then switching won't solve anything.
    What size is it?
    Are you having any water issues?
    Jun 2013
    Auburn, AL
    16
    No water issues. When you say size I assume you are talking the size of the pool? If so the pool is a 14x28 fiberglass pool.
    Jonathan Smart
    22,548
    I should have been more clear. I meant the size of the filter. However my next question would have been pool size.
    38,283
    You have 2 thread now going that are related ... thus making everyone confused:
    pool-filter-issues-t62764.html
    Quote Originally Posted by Smartspool
    We disagree as you have now stated you have algae in the other thread.
    You issue with the current filter seems to be chemistry related.
    Jun 2013
    Auburn, AL
    16
    I am not sure of the size but the type is a PLM100.
    Jonathan Smart
    38,283
    You pool is likely around 11k gallons (depends on the depth). You filter is a 100sqft cartridge.
    We would recommend a minimum of:
    163 sqft cartridge
    2.1 sqft (19.4" diameter) sand
    So you current filter is certainly on the small side which is contributing to your constant cleaning ... compounded by the apparent existence of algae.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Your filter must be undersized. I have had to clean mine once after 8 months of use. Either that or you have a very large amount of debris and/or an algae problem. If the large amount of debris is a problem, sand would probably be a better choice.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
