Thread: Need New Filter - Recommendations?
    Jul 2012
    San Diego, CA
    96
    It appears I need a new filter. I noticed I was constantly having to bleed air from the filter, and despite checking all my pipes for leaks there were none. Then I noticed the paver my filter sits on was sinking. Sure enough, when I cleared the leaves and gravel away from the base of the filter there was a nice puddle. Checked everything and it appears there must be a crack on the bottom of the filter creating a slow and constant leak. Great.
    Anyone want to recommend a new filter to me? It would be great if I could find one that is shorter then the clean and clear 150. Currently, I have everything but the filter under the deck. The dang filter was too tall to fit.
    NEW POOL : 9 x 18, 48" deep - Bestway brand, 1 HP Intex 3200 Pump/Sand Filter Combo, Wanda the Whale, Hayward through wall skimmer (still in box)
    OLD POOL 5,100 Gallons, 9 x 19 used Splash a Round, Intex SWG, 1.5 HP Hayward Power Flow LX pump, Pentair Clean and Clear 150 sq. ft. filter, hard plumbed, Wanda the Whale,
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Need New Filter - Recommendations?
    How high is the deck? Have you looked at what each manufacture offers and are any of them at the correct height?
    Mark
