Thread: gasket interfering with skimmer door
    Mar 2010
    Huntington, WV
    150
    I just realized that my skimmer gasket is squeezed out and it prevents the skimmer door from opening and closing the way it should. Would it be ok to take a knife and cut the gasket that is causing the problem?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: gasket interfering with skimmer door
    That should work. Is it a butterfly type gasket, or two seperate gaskets?
    Mar 2010
    Huntington, WV
    150
    I am not sure.
    24' AGP
    Mar 2010
    Huntington, WV
    150
    Butterfly, I think.
    24' AGP
