Thread: Chemical/Test help!?
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Hi All! This is only my second post and I am waiting for my suggested test kit to arrive... As of right now, I have added about 8 gallons of bleach, 2lbs of Cynuric. The pool is very cloudy and you can see the picture for the chemical test strip results. (I think I need to add PH minus? Any suggestions are very appreciated!!
    24 ft R, Niagara by Asahi Pools, ABG, 13500 gallon, hayward 1hp single speed pump, swim pro sand filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Chemical/Test help!?
    If the strip is to be believed, pH is slightly low, but nothing I would worry about.
    Also note, when you do get your proper test kit, that the pH test may read higher than it is. So don't be hasty about fixing it, or you'll just end up dong that pool store see-saw. accurate-ph-test-during-shock-levels-with-r-007-t61076.html
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Is your water green & cloudy, milky white and cloudy, or ???
    It looks to me like the pH is close to 6.8. Would not add pH minus.
    Looks like your FC is between 5-10 ppm. Also looks like CYA is indeed low. Although you added CYA recently, it will take about a week for those results to appear in your test results. Be careful not to overdose on CYA - it is much easier to add more if needed but more difficult to remove if it gets too high.
    Since it appears you have ordered one of the recommended test kits, I would wait until that arrives and then run a full series of tests and post those results and we will go from there. For now (until your new kit arrives), maintain FC at around 5 ppm or so. It sounds like you will need to go though the Shock Process, but you will need the new kit in order to do that properly. In the meantime, I would remove any debris that may be in your pool.
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Here is a pic of the pool... I guess I would say its a bluish/white cloudy!?! You can not see through it at all...
