Thread: Cleaner Request
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Cleaner Request
    Does anyone make a robot that cleans bottom, walls, and skims? It would be fairly easy to make a robot that sucked water from the bottom and top and blew it out to the left and right. This would give it the normal ability to clean bottom and sides, but with a good top skimmer design, could travel at the top of the water doing skimming passes. My skimmer generally sucks at getting all the little stuff when the wind is blowing wrong. One gadget to do 100% of the cleaning would be awesome! If any manufacturer wants to fly with this idea, I'll gladly sell it to you for the mere cost of one working unit.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Feb 2008
    Denton, TX
    5,061
    Re: Cleaner Request
    Haven't seen anything like that. Effective skimming would require something to be on the surface the whole time I would think.
