Thread: Switching sequestrants
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I did a Vitamin C treatment recently and am on maintenance with Metal Free. I was not too happy with my results and after reading more here, it seems that Metal Free is not one of the recommended on this site. I would like to switch to a different sequestrant and would like to know if there is anything I need to do first or if it is OK to just make the switch by continuing on a maintenance dose with a different product.
    Thank you.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Switching sequestrants
    Just switch to a different sequestrant. Any sequestrant slowly breaks down in the pool, so you need to add more regularly to maintain the correct level - that's normal.
    Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which are noticeably less expensive.
