Results 1 to 7 of 7
Thread: New swg
    May 2009
    Trenton NJ
    497
    New swg
    When my pool was originally plumbed,the installer put an inline check valve after the heat pump and before the swg. I am about to install a new auto pilot swg. Can anyone tell me if I should remove the check valve or keep it, reinstall? I assume it has to be installed vertically.
    Thanks
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    38,271
    Re: New swg
    You usually do not need a check valve there. The type of check valve affects the installation orientation if you are going to put it back.
    May 2009
    Trenton NJ
    497
    Re: New swg
    I am leaning towards not putting it in. What's worse case if I leave it out?
    38,271
    Re: New swg
    How worst case? Worst case is hydrogen gas builds up when the SWG is on with no water flow and goes backward into the heater and explodes when the heater turns on.
    This would take multiple failures though and most manuals I have seen do not require a check valve before the SWG.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New swg
    Doesn't sound so bad........
    Essential Links:
    Ft Lauderdale, Florida
    1,455
    Re: New swg
    The AutoPilot manifold, when plumbed with the upper manifold loop upwards, acts as it's own gas trap (hartford loop), so the hydrogen gas cannot backflow with the chance of a failed flow switch and the pump off. Also, the AutoPilot should be wired so that if the pump is off, the AutoPilot should be powered down as well.
    There's little to no concern if you leave the check valve off.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    May 2009
    Trenton NJ
    497
    Re: New swg
    Thank you
