Results 1 to 8 of 8
Thread: Considering a SWG but need advice
    Hello all,
    I currently have a 19K gallon pool with a 1hp Pentair Superflo pump & a DEX 4800 Hayward filter. I add chemicals by hand, but with 2 small children, school and work, I find it difficult to keep up with the chemicals the way I should. For this reason, I am considering a SWG. I am interested in getting a device with a control box that would be able to handle the SWG, but also possibly a PH additive if I chose to add one later. Additionally, I would want one that could hook up to my wireless internet so I could check chemical levels when out of town. I know that the sensors these devices use are not yet sophisticated enough to be really accurate, but it would be great to see about where I stand in terms of salinity, Chlorine, Alkalinity, & PH from a remote location.
    But I have a few concerns:
    1) I only run my pump about 2 hours each day, which seems to keep the water fairly clear. I am concerned that this is not enough time to really utilize a SWG since I understand that they can only produce chlorine when the pump is running. I dont want to run it all day long, but would I need to get a variable speed pump, to really make the whole system work efficiently?
    2) I understand that SWGs often require their own maintenance regimen. That said, I think it would do a better job of chlorination, but might not really save me any time.
    Based on my set-up, would you even recommend a SWG? If so, what brand would you trust to do what I indicated above? If not, what solution would you recommend?
    Thanks in advance for the advice!
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Considering a SWG but need advice
    Quote Originally Posted by loudog98
    Maybe....or you could oversize your SWG if you don't want to run the pump as long.
    There is very little maintenance and yes, they do chlorinate differently...and in my opinion, in a better way. If you keep your levels right, you may only have to clean it once a season. You would spend a lot more time dosing manually.
    Yes. I have a Jandy and hear good things most of the time. If I had a choice I would go with a Pentair setup.
    There are some effective automation solutions out there but I'm not sure you will find one that will do everything you want, especially the chemical levels.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Thanks UN1017. Good to know that a SWG is an option. I am surprised that even an oversized unit would work with only a 2 hour run time, but I am glad to hear it! I appreciate your advice.
    I don't think you'll get away with only a two hour run time. Typically a SWG should be sized for 2-3 times the size of your pool. This usually lets people get away with running 8-12 hours. Some rough calculations would put you in the range of a SWG designed for 100k to 160k. Unfortunately, there are no manufacturers that I know of that make them that big.
    I think realistically, you would be looking at 4-6 hour minimum runtime, probably closer to 6.
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    I see. If that is true, I should look at getting a variable speed pump or using a different solution. Any suggestions?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    2-speed motor would help with electric cost. SWCG is the way to go to help limit maintenance time.
    I did some research, and I am not running my pump long enough to turn the total volume twice per day anyway. I should be running at least 4.5 hours per day. I looked into the variable speed pumps and they would allow me to run up to 12 hours per day at a high enough GPM to power the Creepy Krauly and still save about $450-$700 per year in electricity (depending on what cost tier I end up in for running longer). Now I just need to find a controller that can handle the pump the SWG and connect to the internet. Does anybody have a SWG/control box system they are happy with that allows for at least PH & Chlorine monitoring on the internet & variable speed pump control?
    Where ever you read that is simply wrong. It is extremely unusual for a pool to need even one turnover per day, and nearly all pools are less than that. See the Pool School article on how long to run your pump.
    A variable speed pump is hardly every worth it unless your electric rates are $0.20/kwh or higher. With lower electrical rates the initial investment doesn't get paid back. For lower rates, a two speed pump is your best choice.
    Nothing a residential pool owner can afford reports chlorine levels over the Internet. There are a couple that do ORP, but ORP has at best a tenuous relationship to FC levels and is best avoided.
    There are a couple of different models of automation (at least one from each of the major brands) that do the rest of what you want, but they tend to be pricey.
