Thread: Mustard Algae or dirt/pollen
    Noticed today when brushing the pool these few spots. There are about 4-5 thought the deep end all in the spot where the wall goes from a 90 degree wall to a 45 in the deep end hopper. From reading pool school it sounds like mustard because it is on the wall and it says pollen/dirt will not be on the wall but I really don't know. It is faint but if you look in the middle of the picture you can see a faint yellow color. Don't know if y'all can tell from this or not.
    Here are my test results and they have not changed the past 2 weeks much at all.
    FC- 4.5
    CC-0
    Ph- 7.6
    TA- 60
    Ch- 100
    Cya- 60
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    30,403
    Re: Mustard Algae or dirt/pollen
    I can't see the spots well but tell us what question you have.
    Whether it could be dirt/pollen in that spot. We did have hard rain Friday/Sunday/Monday and the pool had plenty of dirt on the floor but this was yellow looking and in the crease of the hopper in spots. Also in the bottom corner of the shallows.
    It is my understanding dirt/pollen will not be in these spots, only on the bottom of the pool. When brushed these spots disappear.
    30,403
    Dirt typically doesn't accumulate on vertical pool surfaces. I'm still not sure what your question is but it sounds like you may be asking whether or not to shock your pool. The answer is, "yes, shock it"
    Even if it turns out to have been just dirt (not likely) you are out very little money and not much effort.
    If it is mustard algae, then shocking is the only choice.
    Either way, shock the pool.
    Ok. Shock at mustard or regular algae level?
