What chemical am I missing?
You probably aren't using enough bromine. The tabs are usually not enough if you use the spa frequently. You may need to add sodium bromide to create a bromide bank and to add an oxidizer such as chlorine or non-chlorine shock (MPS) after your soak. This assumes you don't have an ozonator. With an ozonator, you usually don't need to add as much oxidizer after each soak.
