Thread: What chemical am I missing?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I use bromine tabs for sanitizing and muriatic acid for pH. Am I missing an other chemicals for my acrylic spa? I noticed that my tub has stayed pretty cloudy after I had a good group of bathers in it.
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: What chemical am I missing?
    I think some sort of oxidizer. See if you can make sense out of this: how-do-i-use-bromine-in-my-spa-or-pool-t102.html
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    There a scary looking thread but I will read up on it, thanks!
    Mar 2007
    San Rafael, CA USA
    12,082
    You probably aren't using enough bromine. The tabs are usually not enough if you use the spa frequently. You may need to add sodium bromide to create a bromide bank and to add an oxidizer such as chlorine or non-chlorine shock (MPS) after your soak. This assumes you don't have an ozonator. With an ozonator, you usually don't need to add as much oxidizer after each soak.
