Results 1 to 14 of 14
Thread: Added DE to Sand Filter - Question/Observation
    Jun 2012
    Goochland, Virginia (outside of Richmond)
    32
    Ok, been using TFP for a long time (above ground pool) on my second year with my inground SWG pool (details in sig) no issues water is crystal clear.
    Pool has been open for a while, it was given a very detailed cleaning prior to adding DE to filter. I slowly added DE and ended up at the 1.5 cup mark for my 1lb of pressure rise. Water was very clean, floor spotless.
    It appears that the water may be slightly cleaner but I have also noticed that some extra dirt and other small trash on the bottom. It appears that adding the DE has somehow helped these things fall out of suspension as opposed to floating in the water. I may just be nuts or have some other cause for this to be happening but I do not know what it is. Is this normal or possible?
    Water looks fantastic BTW. I will post up some pictures later.
    Oh and just because I should...
    Temp 76
    FC 3.5
    CC .5
    PH 7.6
    CH 60
    TA 40 little low going to bring it up
    CYA 40 adding some now to bring it up to 55 to test next weekend
    Borates 20 or so, need to add to bring it back up
    Salt 3200
    Had a lot of dilution this winter and even more this spring.
    16,800 16'x32' IG Vinyl Pool, Buddy Seat, 7' Deep End
    Hayward Sand Filter(1.5 cups of DE), Pentair Pump, SWG Autopilot Digital
    Taylor K-2006 test kit, Speed stir, Borate and Salt Water Strips
    Polaris 9300 cleaner
    Pool Filled First Time June 14th, 2012
    Previous Pool AG Intex 16' Oval, SWG (5 Years)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Added DE to Sand Filter - Question/Observation
    I would doubt it is adding the DE since that should stay in the filter if everything is working right.
    Definitely get your TA up to at least 60 ppm.
    Jun 2012
    32
    I don't think it is DE, I know it is staying in the filter it just seems to me that it was stuff floating suspended in the water. It has filtered something out of the water as I had a pressure rise and had to backwash.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Quote Originally Posted by bacpck
    [center:16t8eegt]Ah hah! We have a clue!
    I&#39;ll bet you didn&#39;t backwash long enough or rinse long enough and spit that stuff back into the pool.
    The only thing the DE did was force you to backwash sooner.[/center:16t8eegt]
    Jun 2012
    32
    Rofl great picture
    It was on the bottom prior to the backwash.. I had to pull 5 inches of water of the pool, I am fairly certain that I backwashed and rinsed it thoroughly.
    It is not a lot of stuff at all just seems to be a bit of extra dirt and stuff on the bottom. Now I did adjust my returns and it could be that it is just collecting differently on the bottom.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Yep.........you're nuts! Different circulation pattern most likely.
    Jun 2012
    32
    Pre DE... take some more tomorrow. . It looks as good if not better now.
    Jun 2012
    32
    After DE
    30,431
    I can't see any difference in the pics. Is it better after DE?
    Jun 2012
    32
    I would think it is better. I can see very little difference in the water (as it was very clear to begin with). I do however think i can see the bottom better, the seam lines on the liner seem much more visible after the addition of the DE.
    I have been filtering something extra out of my water as I have had to backwash. I usually only backwash once a year, with the use of the cleaner that has its own basket I rarely get a pressure rise in my filter.
    30,431
    I forgot to say that DE or not, your water looks terrific.
    Richard320's Avatar
    Jan 2010
    19,050
    The big test is at night, when the light picks out all the floaters for you to see.
    Jun 2012
    32
    Quote Originally Posted by Richard320
    Richard, I agree. I will throw the light on tonight and see what I get and thank you for the compliment.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    LOL! Those pictures look terrible! You need to get a DE filter! Get that pool crystal clear....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
