Thread: Hayward C1200 Cartridge Filter Help!
    Alynn's Avatar
    Jun 2010
    Jacksonville, FL
    52
    Hello again!
    I need some quick help please. I am in the shocking process and went to clean my cartridge filter. Usually, I have no problem, but tonight I unscrewed the top knob and the rod that holds the top came unscrewed from the bottom. I screwed back in, but apparently I can't get it tight enough because now I can't get the top to tighten all the way down to seal.
    I really need to get the pump/ filter back running so I can finish the shock process.
    Does anyone know how to tighten this rod back into the bottom of the filter body?
    PLEASE?????????
    Thanks!
    22,000 Gallon In Ground with CrystalStone (pebble) finish in Blue Ice
    Pentair 1.0 HP Pump
    Hayward C1200 (120 S.Ft.) Cartridge Filter
    Pentair Great White Automatic Pool Cleaner
    TF-100 Test Kit
    Alynn's Avatar
    Jun 2010
    Jacksonville, FL
    52
    Re: Hayward C1200 Cartridge Filter Help!
    Anyone?
    Pentair 1.0 HP Pump
    TF-100 Test Kit
