Results 1 to 16 of 16
Thread: Can I fill from mountain stream?
    Newbie here, first post.
    CYA up to 95, drained about 35%, ready to refill. Can I run a sub/pump and hose from the mtn stream next to my driveway to fill my pool?
    Going to them turn the autochlorinater way down/off and use liquid bleach. To all the info I have gotten from all the great posts, a big Thank You. THANK YOU!!!
    38,540
    Re: Can I fill from mountain stream?
    Welcome to TFP!!!
    People fill from dirty ponds and lakes ... I think a mountain stream would be great water.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Burrrrr I would think about putting a sock or something over the inlet part just to help filter a little. It may slow you down but.....I think would be worth it to not get stuff and or things in your pool!
    Thanks, Read somewhere about bactaria?? in streams and brooks but there is only a mountain feeding this brook. I guess you know better than anyone.
    Been struggling with a bit of a cloudy situation. Alk high, add MA to bring down, then ph down and treat to raise, up goes alk..ugh
    Hardness way down, adding calcium but need many lbs. figure if I can get cya norm, then i can tackle the rest. Wife just wants to get someone here, but I know I can lick this with all the info I can get here. Thanks again.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well you don't hear that question every day! I would say yes, provided there isn't or wasn't mining nearby, or it doesn't contain metals. If not, it might be very nice and soft. However, it will contain micro-bio life forms (algae for one) and I would make sure to stay on top of chlorine extra close.
    Welcome to the forum Judge and let us know how things go.
    EDIT: Wow, three posting at once. Can you post a full set of numbers? It would be most helpful and the only way we can really help you get on track. You can lick this, and it will be rewarding when you do. With your attitude, there is no need to call anyone. There is far more knowledge here anyway.
    Essential Links:
    Yes, going to tape a sock over the hose to catch anything/everything.
    Chlorine is super high right now Thanks
    38,540
    After it is full, it would be a good idea for a full set of test results and then going through the Shocking Your Pool PROCESS to kill off anything that was brought into the pool.
    18,000 gal IG Vinyl
    cya 95
    ph 7.2
    chlor 5+
    alk 140
    hard 90
    38,540
    Is that before you filled back up?
    What test kit do you have?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Wow... CYA 95... it that is reliable, I think I would look at about a 50% refill if possible.
    -- Guy --
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I'll bet that water is cold!
    May 2013
    Miami, FL
    23
    Let us know how it goes...would love to hear how mountain water works out....
    I'm a city slicker
    pool owner since 2012
    13-15k gallons, kidney shaped,in-ground plaster
    1970s construction, currently undergoing complete renovation
    3 jets, 1 skimmer, 1 dedicated vacuum line, kreepy krauly great white, main drain
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Surprised nobody has mentioned this, but ...
    Make sure you have rights to that water before putting it in your pool. This could get you into trouble fast.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    SUPER GREAT NEWS!!!
    First, the stream is on my property, but thanks for the heads up.
    CYA-35, chlor high 5+ to kill off any micros, ph 7.5, alk 70, hard 120.
    Floc last night to find nice layer to vac to waste. refilling with hose
    Pool nice and clear, though a bit chilly but should come up quickly with solar heater.
    Best part is wife stoked! HAPPY FATHER'S DAY
    16x32 IG 18,000 gal
    Hayward S-200 high rate sand filter
    Hayward 3/4 hp super pump
    Hatward CL200 chlorine feeder
    200 feet black garden hose homemade solar heater rolled on black plywood fed with sub pump from pool to pool
    Feb 2008
    Denton, TX
    5,061
    You need a test kit that tests for FC levels greater than 5 ppm. Please see the following link...
    pool-school/pool_test_kit_comparison
    38,540
    Shock level of a FC of 13ppm would be the target to ensure nothing is in the water ... Thus the recommendation for a better test kit.
