Results 1 to 15 of 15
Thread: Pump is running dry when trying to vacuum
    Jun 2013
    Bethalto, IL
    5
    Hello all, new to pools and the board here.
    I am having a issue when I go to vacuum my 15x30 AG pool. It has a new Hayward EC40 and 1 hp Matrix pump setup. After hooking up the manual vac head to a pole, pushing the air out of the submerged hose with the discharge jet, and then hooking it up to the vac plate in the skimmer the pump is filled over half way with air within 5 seconds or so and the pump is gasping for water (which I turn off immediately afterwards).
    I've done some searching on here and it sounds like most people have holes or air leaks either in their hose or elsewhere.... it seems like it would have to be a huge air leak for the problem I'm having? When the pump is running through the skimmer without the vacuum there is some air in the pump for a while and then fills up after running so long.
    Tonight I'll inspect everything I can again and go from there... any other tips or areas to look at please let me know. Maybe the vac plate isn't sealing good, a hose end is loose, etc. ?
    15'x30' AG - Hayward Perflex EC-40 DE Filter with 1 HP Matrix Pump with inline tablet chrolinator
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Pump is running dry when trying to vacuum
    I have not used an adapter plate with my AG pool, I use an adapter cone that came with my Aquabug. I know when I fill my vacuum hose, I need to get all of the air out of the hose before vacuuming, either with the bug or a manual vac head.
    What I normally do is fill the hose with water, start the pump and wait for the bubble to go away in the pump strainer body, fill the last bit of the v-hose with water and then quickly plug it into the skimmer body. I normally get some air but it goes away quickly.
    -- Guy --
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    How high is your water? You may not have it high enough and there is are getting in due to that. I also do not use the plate. I found it did not really work for me. I just push the hose end into the skimmer hole. That works great for me.
    Good luck!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    This is what the end of my hose looks like with the adapter on it
    This is what it looks like plugged in
    This photo was taken during a repair. The pool's water level is low in this shot (the skimmer is full of white crepe mrytle blooms)
    -- Guy --
    Jun 2007
    New Jersey
    653
    I always run the hose through the weir opening to connect to the bottom instead of over the wall. The more hose you can keep underwater the less air you will suck in. This may help you, but it may not be enough to solve your problem. Are there ANY bubbles coming out your returns when you are NOT vacuuming? If there are, this would indicate you have a full-time suction leak NOT associated with the vacuum itself. It sounds like you do, based on the air in the pump without the vacuum. This might allow you to filter ok, but cause a fail when trying to vacuum. Check the big o-ring on the pump trap cover and the little one(s) on the pump drain(s). Also look closely at any valves on the suction side between skimmer and pump. They can leak air, too. Look for any little spurt of water on the suction side when you kill the power. Thar be an air leak...
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jun 2013
    Auburn, Washington
    7
    Mine did that. I learned that you need to put the hose in front of the tube that puts the water back into the pool so it pushes water through the hose. When the bubbles stop coming out of the vacuum, the hose is purged of air, then you connect the hose to the intake thing.
    14,000 gallons 24'x52" Seaspray Allure AG
    Sand filter, 1.5 hp Hayward Vari-Flo XL
    Installed June 2013
    AquaCal SQ120 HeatPump
    Jun 2012
    Louisville, KY
    266
    Sounds like you're not getting the tube completely full with water. Try putting the vacuum in and then slowly feeding the tube into the water vertically, so you are pushing the tube down vertically allowing water to fill the tube. When you go to plug the other end into the skimmer you should see the tube is completely full of water.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Jun 2013
    Bethalto, IL
    5
    Thanks for all the replies and info so far. The water level is 3/4 the way up the skimmer opening. I can not see any bubbles coming out of the return port. I'm guessing I do have a full time suction air leak (and it's not just vac related) .... so last night I took the O ring off the pump trap cover and cleaned/lubed it as well as flushing/re-charging the DE filter. It didn't seam to make a difference and then I ran out of daylight. When the pump is running there is a air pocket the full size/diameter of the pump trap cover and there is a lot of "water turbulence" you can visually see in there.
    Next I'll check the piping from the skimmer to the pump. I do have a center drain that Y's into the piping from the skimmer. I thought I could shut the valve on the skimmer piping and just open the center drain piping valve and see if that makes any difference. Then I'll know for sure it's from the skimmer area...
    Jenischmeni's Avatar
    May 2013
    Indiana
    91
    This could be a stupid question, but I found this out the hard way. Does your vacuum hose have one end with a swiveling adapter and one end that does not swivel? My hose has a swiveling end designed to be attached to the vacuum head (and allow the vacuum head to pivot around.) The other end does not swivel and that attaches to the skimmer. If I reverse those ends, air gets sucked into my vacuum hose and eventually the pump starts sucking only air and no water. It seems that the swiveling end isn't an air tight fit. (I hope that makes sense)
    Central Indiana, 7200 gallon, IG fiberglass, L250 Jacuzzi sand filter, Hayward H150 gas heater, Pentair fiber optic light - installed '06. AOSmith 1.0hp pump, CPSC-24 SWG - installed '13. TF-100 Test Kit.
    May 2013
    Massachusetts
    148
    Quote Originally Posted by hueby
    Make sure you connect the correct end of the hose. Do not connect the swivel end of the hose into the skimmer, it will suck in air.
    I learned that the hard way, bought a new hose, it did the same thing. I found out I was connecting the swivel end into the skimmer instead of the vacuum.
    Doh!
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Jun 2013
    Bethalto, IL
    5
    brownish/green colored water discharge when turning pump on
    Hello all,
    I currently am experiencing about 5 seconds of brownish/green colored water discharged from the outlet into the pool when turning the pump/filter setup on. After the initial start up it clears up. This has been going on for a few weeks now, so I'll change out the DE with fresh and the problem continues. (I also just chemically cleaned the filter tubes thinking that would help) The pool remains very clear though with the pump running 4 hours per day in the morning. What do I need to check and look for first?
    Jun 2013
    Bethalto, IL
    5
    I found the problem of the pump running dry resulting from a air leak in the connection tube from the vac plate and vac hose. I removed the fitting and now stick the vac hose directly down in the vac plate which keeps everything under water as well. The problem is fixed. THANK YOU ALL.
    I am now dealing with the brownish/green water discharge issue posted above.
    30,432
    hueby,
    I merged your other post into this thread. Always a good idea to keep all your issues together so responders can see your whole story.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Is the green coming from algae growing in your hose when it's not being used?
    -- Guy --
    Jun 2013
    Bethalto, IL
    5
    Quote Originally Posted by techguy
    Maybe that is happening? Is there anything I can do to prevent it with still just running the pump 4 hours a day?
