Thread: Growth possible while still passing OCLT?
    Apr 2013
    Chicago IL
    48
    Subject stays it. I always get some dense very localized dark green growth in seams where stairs meet liner and around pool light another seam crevice. A quick brushing breaks it up and vanishes.
    I assume this is due to low circulation/debris collection here. Anyway this is first year of BBB method and thought (hoped) I may not have the issue this year. Full disclosure I haven't been brushing and I probably should do it more regularly, but pool is crystal clear otherwise.
    FC has been consistently around 8 or bit more with CYA level of about 50-60. FC consumption doesn't seem out of line and I pass the OCLT. Yet this stubborn stuff still seems to be able to grow.
    Normal and have to live with it? Or start shocking?
    ~15k gal oasis shape, IG vinyl, 2 speed superflow 1HP ~6' above pool level, pentair TA60D 60GPM/325# sand, built 2004, intermatic 1353 and stenner chlorine injection pump, dolphin robot, and a filthy light niche
    30,431
    Re: Growth possible while still passing OCLT?
    Bazinga
    It is almost impossible to keep chlorine perfectly distributed in a pool. Brushing gets the nasties up out of their nooks and crannies and exposes them to the more active areas of chlorine and they vanish.
    I wouldn't shock but I would sure stir them up.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Can you aim the return eyeballs that way to keep stuff from settling there?
