Results 1 to 18 of 18
Thread: Exactly why I searched and found this website years ago.
    bmann71's Avatar
    Aug 2007
    Washington, Indiana
    55
    This guy reminds me of the reason I found this website. My local pool gal seemed like a knowledgeable enough person to trust but when I asked the question “why can’t I hold chlorine?” she gave me the reason. “Some years pools just act differently and this year I’m seeing a large number like yours, you just have to add more chlorine and make sure your tablet feeder stays full”.
    Is he ignorant in the link between CYA and chlorine or smart enough not to let people know??
    http://www.youtube.com/watch?v=K8De1RaQAKc
    Ponduke
    20,000 gal/ Fiberglass IG/ Sta-rite s7m120 cartridge filter/Sta-rite SR400NA 400,000 btu heater/Polaris 360 Cleaner/K-2006 Test Kit
    poolcalculator
    Pool School
    30,432
    Re: Exactly why I searched and found this website years ago.
    I started to watch the vid, noticed the TABLE FULL of chemicals, and shut it off.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Wow what a mix of dated, and questionable information with a few truths sprinkled in the mix.
    Typical pool store method, any problem is solved by a one time dose of something, if that does not work, do a bigger one time dose, and if that does not work, keep dumping in stuff until it gets better.
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Shock every 1 to 2 weeks huh?
    I haven't shocked a single time since discovering TFP, and my CC's have never been above 0.5 PPM. Never been cloudy. Never had algae.
    Too bad, because up until that point, he explanation of chlorine / chloramines was relatively accurate.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Did you know if you have a "chlorine breakpoint" situation you need to raise the the Free Chlorine level to 10X the current chlorine level. So, if you are at 3 PPM you need to go to 30PPM.
    Also, you "Cannot OVER SHOCK" your pool.
    Monopersulfate shock sounds very expensive.
    Interesting mix of good and bad.
    -- Guy --
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    wow .....
    chlorine demand test
    gassing off
    and no mention of cya level
    and he earns a living doing this ... i have given some serious thought to starting a pool maintenance business
    at the end he gets into the fact that he is a pristine blue guy .....
    i have all of 3 years experience with a pool and i can tell you for an absolute fact that the screws in my bottom drain are phillips head
    nuff said?
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Really. What would you expect from a pool chemical salesman? The truth? Hardly!
    Watched about 3 min of his drivel. That's all I could stand of it.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I lasted 1 min 45 sec. He gave me the itch.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I only got as far as why a weekly shock is necessary. Didn't note the time; don't want to go back and look at it again to see how long that was.
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Poor misguided man.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Poor? I think rich from selling people a bill of goods in pool care!
    bmann71's Avatar
    Aug 2007
    Washington, Indiana
    55
    Quote Originally Posted by Charlie_R
    My original point was that this is the level of information everyone pretty much gets from all their local pool guy. For the life of me I don't understand how people maintain their pool w/o knowing the information we all know here.
    Dumb luck I guess...
    Ponduke
    poolcalculator
    Pool School
    Sep 2012
    Mid-Michigan
    127
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    I'm a new pool owner who had a green pool at the end of April
    I found this website and I have never looked back
    I haven't shocked since then
    The one and only time I went into a pool store was just to see if they had some calcium to raise my ch some
    Felt like they were looking down their noses at me when i told them I do all my own testing
    Now I'm trying to get my brother in law to come here and see the truth about pool care
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    Richard320's Avatar
    Jan 2010
    19,067
    Quote Originally Posted by SkyKid
    Invite him to the house. Water speaks louder than words.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by bmann71
    You're done SLAMing when:
    SkyKid's Avatar
    Apr 2013
    137
    Richard
    He has seen and been in the pool
    He just said I'll keep doing it my way
    Mar 2007
    San Rafael, CA USA
    12,082
    Smaller pools, short swim seasons, water dilution from weekly backwashing sand filters and summer rain overflow can all prevent the CYA level from getting too high and if the pool is closed over the winter the CYA can drop further. Also, the water can be low in algae nutrients (phosphates and nitrates). Weekly shocking can partially make up for too low an FC/CYA during the week. Algaecides or phosphate removers are sometimes used. True luck would be not getting any algae spores into the pool at all, but is unlikely.
