Results 1 to 10 of 10
Thread: Newbie sand filter question
    May 2011
    London, UK
    46
    Hi All,
    Please firstly excuse my terminology, I'm no expert!
    Is it normal for the handle on top of my sand filter which has around 8 settings to release water from the backwash outlet even when simply being depressed / turned?
    Thanks
    Daz
    CERLAND OCTAGONAL ABOVE GROUND POOL
    38,290
    Re: Newbie sand filter question
    Is the pump off when you are turning it (like it should be)?
    How much water are we talking about?
    May 2011
    London, UK
    46
    No. The pump is on. oops!
    38,290
    Then yes ... lots and lots of water
    May 2011
    London, UK
    46
    I've just started the pool up, given it a shock and added some algaecide. There's some dirt on the bottom in places which is settled 'dust'. What's the best method of getting rid of it as the vacuum just disperses it into the water?
    38,290
    Vacuum slower ... at least that is what I have read here (I do not vacuum).
    You are aware that you should never need to add algaecide and that the Shocking Your Pool is a PROCESS and not a one time addition of some product called "shock"
    Post up a full set of test results if you would like suggestions.
    May 2011
    London, UK
    46
    Everyone you ask would have a slightly differing opinion I guess. Does the algaecide do any harm?
    38,290
    Well our opinions are certainly different than the guy looking to make a sale.
    Many algaecides will only hurt your wallet. But some add copper to the water which we NEVER recommend as it can result in staining and green hair.
    May 2011
    London, UK
    46
    Oh mine is copper free!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by darrenkarp
    Not on tfp. On here, the only time I can think of that it is commonly recommended is when doing an ascorbic acid treatment, or as extra insurance when winterizing (I don't use it when I winterize).
