Thread: Changing Pool Light Housing
    Jan 2013
    Atlanta, GA
    13
    We just moved in and I have been working on fixing up our first pool. I noticed the light in the pool didn't work so I thought it would be an easy fix to change it. Turns out it was full of water and there was no bulb (Also looked like something died in it).
    So I am guess I need to replace the whole housing. I cant find this same one, so what would be a good replacement? Also do I just unscrew the cord and install a new fixture, or do I have to drain the pool some and replace it inside the pool wall?
    Here is some pictures http://imgur.com/a/zSTto .
    Thanks.
    Built 1994 25k IG plaster pool with waterfall spa, 1.5 HP Standard Motor - Full Rate , Hayward S244S Sand Filter
    Polaris 380 Pool Cleaner, TF-100 test kit
    30,432
    Re: Changing Pool Light Housing
    I think you will find the cord will not unscrew. Typically the crod and te light housing are one complete set. You should be able to purchase a new buld, put a new seal (gasket) in the fixture and then put the fixture back in your pool.
    If you cannot reuse the fixture, the new one will come with a cord and you will have to pullout the old cord and fixture and then fish the new cord back up to the junction box.
    Jan 2013
    Atlanta, GA
    13
    So you think if I clean out the inside of the fixture it might still work?
    30,432
    I couldn't possibly tell from a pic but it might be worth a try.
