Page 1 of 4 1234 LastLast
Results 1 to 20 of 65
Thread: HELP PLEASE!! Edit: Pump Sucking Air!
    Guest
    Ok experts, need some help.
    History: Pool was opened 2 years ago and cleared using BBB. Could not open last year, left it sit. Cover fell in, turned to swamp again.
    This year, topped off, trying to clear, 3 days in. Per the TF-100 kit:
    FC Shocking at 12
    CYA measured 0, added 1.75lbs of stabilizer 3 days ago, measured around 20-25 but I know it takes a week to show up on tests
    TA 150
    PH measured high at 8.2, added the required acid but cannot measure again due to FC
    For the first two nights, I added the required bleach per the calculator around 10pm, woke up at 9AM to 0 FC. For the first time today, woke up to 1 FC.
    I have been vacuuming and drudging out the pine needles from the bottom daily. Yesterday I pulled out a dead squirrel from the bottom. I worked at it for a few hours until I was pulling up nothing from the bottom from everywhere and brushed the walls.
    The water turned from brown to gray (and I mean gray, it looks like slate rock) on the first day but no change since.
    I am testing 3-4 times a day and adding bleach after, cleaning filter as needed. I am burning through bleach like crazy but am gaining nothing. Visibility is not moving from about 2 inches then solid gray, no progress.
    Any advice?
    Re: HELP PLEASE!!
    What's the CC been reading?
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    Re: HELP PLEASE!!
    Keep at it! I think I went through about 100 jugs of bleach over a couple of weeks before I was finished shocking.
    23,000 gallon gunite with waterfall, radiant heat, sta rite system 3 cartridge filter 450 sq. ft., 1 1/2 HP
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: HELP PLEASE!!
    At the very least we need fresh FC/CC readings.
    Since you have a good kit, full results please. Was the water brown when you started?
    Essential Links:
    Jun 2011
    Long Beach, CA
    2,790
    Re: HELP PLEASE!!
    If the FC drops below 10 ppm, check the pH and lower it 7.2 before adding chlorine again. It is not clear if you measured the pH at 7.2 before you started. When the pH measures 8.2, it can higher than that and the amount of acid could be more than what you put in.
    Seems like you are on the right track, but need to keep the FC at shock level as much as possible, might target 12 ppm while it is burning up the chlorine.
    Guest
    Re: HELP PLEASE!!
    Quote Originally Posted by rdhetrick
    Just retested FC and CC.
    FC: 9 (going out now to bring it back to 12)
    CC: 5.5
    Guest
    Re: HELP PLEASE!!
    Quote Originally Posted by Brushpup
    Between my first post and the one above I have provided all the related test results.
    Yes
    Guest
    Re: HELP PLEASE!!
    Quote Originally Posted by ping
    I can't let the FC fall low so I can test the PH again AND keep the FC at shock level as much as possible. As I understand from pool school the PH has no bearing on getting the water clear, so I was going adjust the PH after the shock is over.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: HELP PLEASE!!
    Others may not agree, but I would continue shocking if it were mine and worry about the pH later since you did add the calculated amount of acid. The pH does effect chlorine effectiveness, but that is better for another discussion. IMO you ought to be close enough to complete a shock. We know you need it, and I would say go on with it.
    Essential Links:
    Re: HELP PLEASE!!
    I wouldn't worry too much about the pH either, as long as you don't think it is real low (<7 or so). Stay the course, as long as you're still seeing high CC like that, there is a lot of stuff being killed. Could be a lot of things, but chlorine is the cure-all!! The more often you can test and re-dose, the quicker it will clear.
    38,547
    Re: HELP PLEASE!!
    Since you had the FC at 9ppm (which is less than 10ppm), I would have then checked the pH and adjusted it back down to the low 7s. And then bumped the FC back up to shock level.
    EDIT: Although re-reading looks like you added acid, but did not bother to check it before raising the FC. Check it is the FC drops low enough, but likely you are fine.
    Guest
    Re: HELP PLEASE!!
    I didn't know this, it could have been higher than 8.2, that's just the max the test will report. What do you guys think, let it drop and check PH again? I had no idea PH effected chlorine.
    Guest
    Re: HELP PLEASE!!
    Jbizzle can I get a good reading at 9FC? If so you think it is worth it to let it fall to that and adjust?
    Mar 2013
    Waco,Tx
    43
    Re: HELP PLEASE!!
    Im not a pro by any means but id shock the **** out of. Higher than your 12. Thats what i did. Couple of days I was good. I also assume your pump has been running non stop. But with it being an above ground pool why dont ya drain it, clean and refill? Easier than an IGP
    32k gallon Inground lazy L with Vinyl Liner. Pentair Superflo 1.5hp pump with a sand filter. Liquid Chlorine
    38,547
    Re: HELP PLEASE!!
    Yes you can get a good reading at 9ppm. In reality, reading the pH test immediately, should get you a pretty good result since you are just above the 10ppm "limit".
    If you are at FC of 12ppm and the pH test does not look like 8.2, you are probably good. Being only a little high on the FC should not have a huge impact on the pH test.
    38,547
    Re: HELP PLEASE!!
    Quote Originally Posted by Sack
    That is not the method we recommend. Doing so puts your pool and equipment at risk. Also most permanent AG pools can not be drained without putting the liner at risk.
    Mar 2013
    Waco,Tx
    43
    Re: HELP PLEASE!!
    ok then that makes sense. Ignore me then
    Guest
    Re: HELP PLEASE!!
    Ok it dropped to 8 by the time I got off of work, retested PH showed 8.2 still, added 23oz if acid per the calc, how long do I need to wait before I can test again and get back up to shock level?
    Edit I forget to adjust my TA in the calculator, it said I needed 40oz, added it.
    38,547
    Re: HELP PLEASE!!
    Let the water circulation for 30-60 minutes and test the pH again.
  20. Back To Top    #20
    Guest
    Re: HELP PLEASE!!
    OK thank you.
