Thread: Test Results - need help with Chlorine
    Hi all,
    We just had approx 80-90% of our water removed and refilled due to high CH and CYA. I guess we are in Pool start up mode, below are my test results and I can't seem to keep the chlorine up. If I used and understand the pool calculator, i needed to add 130-150 oz of bleach (which i did) and it raised the chlorine up to 3 or 4ppm but drops to 0 or maybe .5 in 12-24 hours. is this what i add everyday as maintenance, or is there another way to reach 2-3ppm and then maintain it? Feel i'm doing something wrong or didn't understand something along the way. Thanks for the help!
    FC 0.5
    CC 0.5
    pH 7.6
    TA - 80
    CH - 180
    CYA - 30
    Phosphates - 200
    24K Gal, IG Gunite/Plaster, 2.5 HP Jandy Stealth Pump, Jandy CL580 4 cartridge filter, Ultra Pure Turbo UV Ozonator, polaris
    Re: Test Results - need help with Chlorine
    Welcome to TFP!
    Chlorine gets used up every day and needs to be replaced. With CYA around 30 you will be losing 2/3rds or more of you chlorine each sunny day, more if people are swimming.
    With CYA at 30 you want your FC level to be between 2 and 7 and never below 2. Typically that means raising it to 6 or 7 each day so that by the next day it will still be at least 2.
    You will save chlorine if your raise CYA to around 50.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Welcome!
    Those aren't pool store results, are they???
    If those readings are correct, then Jason told you what to do. If they're not - and pool store results are not always accurate - then you could have higher CC which would indicate an impending algae outbreak.
    Have you read Pool School?
    wow - so that's approx 300oz's of 6% bleach for day 1, and if it drops to approx 2ppm i would add about 200oz's moving forward. Sound right? I guess that seems like a lot of bleach and don't want to over do it like i believe i did before on Chlorine pucks/stabalizer/shock etc that raised my CYA upto 150 or so. I understand the bleach shouldn't effect the CYA, but afraid of overdoing something again
    Hi Richard - thank you for the reply. Those are the results i used with a Taylor kit. I have read the pool school, doesn't mean i've retained everything but have read it and believe i'm on track. I did see the CYA-FC diagram etc, just afraid of over doing it or if there was a basic pool "start up" that's a different calculation then the pool calculator that seems to be more maintenance. Didn't realize how much bleach i would need to keep on hand.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, 24K Gallons is no small amount to shock. Keep at it and let us know how it goes. Don't worry about over-doing bleach, but be careful on over-doing CYA.
    Essential Links:
