Results 1 to 12 of 12
Thread: Recommend against the chlorine tablets in the floatie?
    May 2013
    Miami, FL
    23
    So from the reading I've done, is it accurately to conclude that the folks here highly recommend against the chlorine tablets in the floatie?
    pool owner since 2012
    13-15k gallons, kidney shaped,in-ground plaster
    1970s construction, currently undergoing complete renovation
    3 jets, 1 skimmer, 1 dedicated vacuum line, kreepy krauly great white, main drain
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: BBB for Beginners
    Quote Originally Posted by tmnt25
    Short answer: yes.
    Long answer: We don't really care how you chlorinate your pool, provided the source you're using has no unwanted side effects. Pucks have their place. They're great for vacations. But they add stabilizer, lower pH, and lower TA while adding chlorine. Why buy pucks if you have to keep adding pH up and Alkalinity increaser? And as the CYA in the pucks builds up, the effectiveness of the chlorine gets reduced to the point of uselessness. And then comes the algae bloom the pool store can't cure no matter how deep they dig in your wallet. Here's just one such testimony: hi-new-member-why-didnt-anyone-tell-me-this-t62103.html
    May 2013
    Miami, FL
    23
    I like to take my cya up from 20 to 30...could I do this with pucks? Do we know the numerical effect pucks have on cya?
    Richard320's Avatar
    Jan 2010
    18,967
    Yes. If you plug your pool size in at the top, then scroll waaaay down to Effects of Adding Chemicals, you can see what each 8 oz puck will do to your pool chemistry.
    http://www.poolcalculator.com/
    38,242
    Re: Recommend against the chlorine tablets in the floatie?
    Use the bottom of poolcalculator.com
    The effects of chemicals section will tell you what a puck (trichlor) will do to your pool.
    Jul 2011
    phoenix
    133
    you can buy conditioner/stabalizer and add a a little bit in a sock, then hang said sock in front of a return jet. Did this myself when I drained a month or so ago
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    May 2013
    Miami, FL
    23
    thanks, i didnt know that tool was down there in the pool calculator. Rather than buying stabilizer, i figure i might as well use the pucks i already have.
    are there pucks that DONT add cya? My reason for asking is that my pool guy has been putting in pucks(different from the ones i have) over the last year and my CYA is only at 20...
    38,242
    Most pucks are trichlor that add CYA. There are some that are cal-hypo which add calcium, but they dissolve too fast and are not very common.
    May 2013
    Miami, FL
    23
    hmm that's strange...i think i might be doing the CYA test wrong....I see that black dot until the whole container is full!
    With over a year of pucks, it doesnt make sense that the CYA is so low.
    38,242
    You get a lot of rain right? Have to drain the pool often? Could be diluting the CYA.
    What do the rest of your tests look like? Sometimes the CYA is broken down by bacteria over the winter (not that you really have a winter).
    And how are you testing?
    May 2013
    Miami, FL
    23
    I do get a decent amount of rain...maybe have to drain 2-3 inches once a month for 3 months during rainy season....
    The rest of my tests look pretty consistent since i took over the pool duties 2 weeks ago. FC hasnt been dropping drastically, even after 3 people took a swim on a really hot day.
    I'm testing with the TF100....indoors by an LED bright white light. pinch a penny tells me my cya levels are closer to 40-60....i get 20.
    38,242
    The CYA test should be done outside with your back to the sun:
    extended-test-kit-directions-t25081.html#p206397
    Lighting can affect the CYA test a good bit.
