Results 1 to 8 of 8
Thread: Broken deck and loose rock
    May 2011
    Granite Bay, CA (Sacramento area)
    99
    A piece of our deck broke off. What would be the best way to replace/repair it?
    Also, one of the rocks by the side of our pool is loose. What would be the best way to reset it?
    Thanks!
    18,000 gallon IG gunite freeform pool
    Intelliflo VS pump; Hayward SwimClear-C4030 425 sq ft filter; 4x suction PoolCleaner
    Re: Broken deck and loose rock
    Curious too..
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    May 2011
    99
    Hi Helen-
    I ended up using PL Premium Fast Grab.
    http://www.loctiteproducts.com/p/pl_ca_ ... hesive.htm
    It is holding very well (strong stuff). People have stepped on the rock, and it hasn't budged at all. The color ended up being kind of beige, which didn't really match our gray based deck. But I don't really care. You only really see it if you look right at it. Time will tell how long it will last, but I'm guessing it will do very well over time.
    Thank you! I think I may have tree roots buckling up my concrete deck and rock work. I wasn't sure what to use. Even if it lasts a few years, that will be a help!
    Helen
    May 2011
    99
    Bummer about the tree roots. Can you cut the roots without endangering the tree?
    Well, I don't think so. It's a huge Red Oak.. The PB told us we may have trouble.. but we thought we'd try.... It is our only shade tree in our back yard.
    Helen
    May 2011
    99
    Yeah- don't want to lose the shade.
    Good luck with it!
    If you never want to worry about it again, use hydraulic cement. I may not have been on this board very long, but I have worked in the building industry long enough to tell you that is one of the strongest concrete products out there. Its bond is so strong, you could actually set it underwater in the pool to seal a crack in the gunite/shotcrete shell.
