Results 1 to 8 of 8
Thread: hard plumb intex: Please post pics of electrical conduit
    May 2013
    Chandler Arizona
    78
    Looking for pics of how exactly to use the grey electrical box adapter in the hard plumb install. Is it used to replace the intex hose and still using the intex grey locking nut that comes with the intex hose?
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    Apr 2013
    Battle Creek, MI
    298
    Re: hard plumb intex: Please post pics of electrical conduit
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    May 2013
    Chandler Arizona
    78
    Thanks for the link!! exactly what I was searching for
    Jul 2009
    S. California
    157
    Thanks CeeElGee ! I have never seen that before and it is really helpful. Great job!
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by Livinright
    Someone added that thread recently because there had been a lot of inquiries just since I joined. Most, if not all, of the older threads on the subject had pictures that weren't viewable anymore.
    May 2013
    Littleton, NH
    22
    I just did this and let me say it worked pretty good but don't get antsy. let the pvc cement harden at least 1 hour before putting any water through (better if it's 2 hours).
    Intex 18' X 48" Hard Plumbed running the 1800gph pump that came with it. Using BBB method
    May 2013
    Chandler Arizona
    78
    So i have the regular PVC blue glue stuff for the white PVC, I see you used the purple primer with the clear pvc cement? Do you know what the difference would be? Do you use the primer and clear due to the grey and white PVC mismatch?
    May 2013
    Littleton, NH
    22
    as long as your primer and cement are for pvc you should be fine.
