Thread: liner wrinkled from vacuum
    wmorge's Avatar
    Jun 2013
    Terre Haute, Indiana
    81
    Last year my vacuum kept getting stuck and by pulling it off without turning pump off realized I wrinkled my liner in 3 spots. I discovered my brush bristles on the vac were all broken down..which caused it. Should I be concerned.. fix it now or ignore the wrinkles until I spring a leak? Hopefully that wont be the case. I bought a new great white auto cleaner and have been using it this year to clean up the green so hopefully it wont wear down those wrinkled areas..
    16x32 I.G. Vinyl, Hayward Pro High-Rate Sand S220T, Vari-Flo XL Valve, Hayward Super Pump 1Hp , Great White cleaner, Hayward W530 Leaf Canister, TF100, Pool Skim.
    22,544
    Re: liner wrinkled from vacuum
    You can take a plumbers helper (rubber plunger) and see if you can move them, but you probably won't be able to and it full of water. I wouldn't worry too much about them.
