Results 1 to 17 of 17
Thread: How do I vacuum an 18' Intex Ultra Frame?
    I haven't installed the over the wall skimmer since I think it's a piece of ****, so the only intake is the intake on the wall under water. I want to buy a manual vacuum today when I go get my water tested, but I have no idea what I need to buy. Will I simply take some hose and plug it into the intake on the wall of the pool and connect that to the vacuum? If so, does anyone know what size hose I'd need to fit into that intake? Thanks.
    Intex Ultra Frame 18'x48"
    Intex 14-Inch Krystal Clear Sand Filter Pump
    Intex Intex Krystal Clear Salt System (not yet installed)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How do I vacuum an 18' Intex Ultra Frame?
    I imagine it is 1.5 inch. Im not up on these fittings, but there are lot of threads on the subject. The skimmer is junk IMO, but I am sure there are folks who like it. With the correct size, yes, you just plug the hose onto the fitting inside and attach to whatever vac device you get. Something simple will do and is all you need. Some Intex come with a little vac nozzle made for a water hose, but you can plug that hole on top with a water hose connector X 3/4" threaded and put a 3/4" threaded plug into it. Then stall your vac hose to the thing and away you go. I did and it works OK, but I just get in and use the hose end most of the time. Been doing that for years.
    Essential Links:
    Jun 2013
    Buffalo, NY
    80
    First post here and I can definitely help as I just did this yesterday.
    I have a 16' ultra frame and did the following:
    1) purchased a vacuum head at the pool store
    2) purchased 1 1/4" hose
    3) shut off filter
    4) Unscrew the cover on the lower filter intake of the pool. Note: just the cover, not the actual attachment itself
    5) the hose I purchased is able to be pushed directly into the filter hole
    6) make sure the hose is completely filled with water
    7) connect vacuum head to hose
    8) start up filter and vacuum away.
    Hope this helps.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    Quote Originally Posted by Synergy2
    3) shut off filter
    Hope this helps.
    Thanks! I'm assuming mine also has the 1 1/4" holes then.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would check before I bought a section of vac hose. I have a 15' that has 1.5 outlets on the inside. Nothing is standard with Intex though...that you will come to know.
    Essential Links:
    Jun 2012
    Pennsylvania
    44
    I posted this elsewhere in another thread the other day, but I will post here too. I got a 1 1/4" vacuum hose from the pool store. On the end that swivels and attaches to the vacuum head I wrapped a few rounds of electrical tape around it in order to make for a snug fit in the Intex vacuum head (the one that came with the pool). I pushed that into the vacuum head where you normally tie on the mesh bag. The other end of the vacuum hose will fit into the hose that goes to the skimmer basket that hangs on the wall. I don't know if it will fit directly on the intake but you could try it. I put the hose in the pool, and then hold it over the return for a minute or two with the filter on in order to flush out any air, and then connect it under water. I also take a knee high panty hose and put a few inches into the hose before connecting it to the skimmer hose to make a "bag" of sorts to catch the debris. Otherwise it will all get caught on the screen of the intake and it's hard to clean off without it all falling back into the pool.
    This method worked well for me with the smaller Intex pump that came with the pool. I've since upgraded to the sand filter and it works much better now with more suction. I just had to cut the grate off of the intake so that the leaf basket on the filter could catch the debris instead of clogging up the intake, so now I don't have to use the pantyhose and empty it constantly while vacuuming if there is a lot of dirt (which there usually always is...the fun of living in the woods!)
    16'x48" Intex Ultra Frame Pool
    Intex 2650gph Sand Filter Pump
    Intex SWG
    Quote Originally Posted by wozzukes
    So the grate on the return doesn't unscrew? That's a joke.
    Jun 2013
    Buffalo, NY
    80
    I should also note that the vacuum head and hose are not Intex brand. I am not sure who makes them but they are definitely not intex.
    Agree with you on the upgraded filter as well, that was one of the best things I did. I didn't even open up the filter that came with the pool.
    Intex 16 * 48 Ultra
    Hardplumbed in 2014
    TF100 Test Kit
    Yeah I sold the stock filter on ebay for $60
    Jul 2009
    S. California
    157
    The Intex maintenance kit I got came with a blue adapter that screws onto the intake fitting. There should be threads there for this. Even my last 18' Easy Set pool had the threads. Once screwed on, the adapter has a slip on connection for the vacuum hose. Easy.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Livinright
    Mine too.
    Essential Links:
    Jul 2013
    Long Island, NY
    532
    Will this work if you don't have an over the wall skimmer? Am I just unscrewing the cover to this item on the right and putting the hose through? And the cartridge filter will get the dirt at the bottom?
    Attachment 31933
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    May 2015
    canada, montreal
    28
    what can i do if i want to vacuum my pool and i have 2 intake hole and 1 output hole ? if i connect the vacuum to only one of the 2 intake hole does it going to suck enough?
    thanks
    or if you have idea thank you
    18 X 52 intex ultra frame pool, intex sand filter 1600 gph
    Jun 2015
    Jacksonville IL
    1
    I have that exact same question. We have 2 intakes also . We have been told to hook the hose up to the skimmer basket that is attached to the sand pump but it doesn't work . Beginning to think our pump isn't big enough but it's not a option to upgrade right now .
    20x52 Intex with 1/2HP sand pump, no skimmer on the side of pool. Skimmer basket attached to the sand pump.
    jmcdtucson's Avatar
    Jun 2014
    317
    I think you will have to block one of those intake holes to get enough suction. They don't have a valve to close them? You could cover with a plastic bag
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jul 2015
    Ocean County , NJ
    7
    Does anyone use a robot vacuum in their intex? Not sure if it would be too rough and rip the liner. I have an Aquabot Jr.
    Cornelius Miramar ag 18' x 48" round
    Splash Line by Jacuzzi 16" sand filter 1 HP Hayward pump
    Apr 2015
    Western, WA
    37
    I just got the intex auto pool cleaner for our pool. Not a robot, but an 'automatic' pool cleaner. $50 on Amazon. Time will tell how well it works. I like that is is a discharge side cleaner, meaning it won't burden my existing sand filter with more material. A suction side cleaner would. There are a few youtube reviews of it. I saw this one (posted by a member here I believe) which helped me with my decision: Intex Automatic Pool Cleaner Review Part 1 - YouTube I too was researching robots of various makes up to $600 but eventually decided I'd give this a try first.
    AG Intex Ultra Frame 18x48 - new for '15. TF100 test kit. Intex 3,000 gph sand filter/pump, Solar Cover, Intex magnetic pool light, Hayward Skimmer, Laars 250kBtu/hr NG heater. Intex SWG.
