Thread: How does the LQ work?
    Jun 2013
    Lazio Italy
    41
    We are trying to change over to the bbb method and I have read about the Liquidator. Could anyone tell me exactly how this works? Does it only work with liquid chlorine or can you use bleach in it? I assume there is some sort of container to fill which releases the liquid. If this is the case, how long does each refill last? Does anyone know if they are available in Italy, or, if not, a company that would post to Europe?
    23k, IG,Vinyl, sock, 5 years.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How does the LQ work?
    You have a tank full of water with floats on the input and output to maintain water level. You add the liquid chlorine to the water via a long funnel so it goes to the bottom of the water. The bleach or liquid chlorine (same thing) remains in a layer on the bottom and strongly chlorinated the water above which feeds into the pool slowly.
    Jun 2013
    Lazio Italy
    41
    Thanks for the info John.
